engine oil in radiator
Old Nov 29, 2017 | 07:37 PM
yeoldrustbucket's Avatar
yeoldrustbucket
Question engine oil in radiator
I have a 2000 Dodge Dakota. I have engine oil in the radiator. There is no coolant in oil, no transmission fluid in radiator, no coolant in auto transmission reservoir. JUST engine oil in radiator. What could be causing this???
Old Nov 29, 2017 | 07:52 PM
cruzer55's Avatar
cruzer55
Blown head gasket,do in pairs for fix,left & right.Just a thought........................................... ................
Old Nov 30, 2017 | 05:45 PM
magnethead's Avatar
magnethead
are you sure it's motor oil and not transmission fluid? Very possible the tanks cracked between the trans cooler and radiator That's what wiped out my transmission, turned the trans fluid to milk.
Old Dec 2, 2017 | 06:13 PM
yeoldrustbucket
Nope, definitely oil in radiator.
Old Dec 2, 2017 | 10:01 PM
00DakDan's Avatar
00DakDan
Section Moderator
What engine are we talking about?
Old Dec 4, 2017 | 12:24 AM
blascameron@live.com's Avatar
Can still be a blown head gasket or a cracked head or block. coolant wont always be in oil pan. It depends on which passages where the block meets the head are compromised.
