2004 Dakota short help
Old Jan 11, 2018 | 01:37 PM
pTacRP's Avatar
pTacRP
Default 2004 Dakota short help
Recently I've noticed that when I press the brake pedal my dash lights illuminate and when I let off they go back off. Also when I activate the right turn signal the signal indicator flashes and makes all the dash lights flash as well. Lastly I discovered that when I press the brake pedal the front parking lights go on and then off when I release it. Is there a ground that I can check on this? My cluster was recently removed and put back in so is there a chance the wiring was messed up when it was put back together?
Old Jan 11, 2018 | 02:31 PM
Yes. There is a chance the wiring was messed up when it was put back together.
