2004 4x4 engine swap
Old Jan 21, 2018 | 10:45 AM
oregun's Avatar
oregun
Default 2004 4x4 engine swap
I'm looking into a 2004 v6 4x4 Dakota with a bad engine.
my question is what are my options for a replacement engine?
I found a 2003 with a V8 4.7l. could I simply swap that in? Or would I need additional comments?
Old Jan 21, 2018 | 11:32 AM
magnethead's Avatar
magnethead
Only thing that can replace a 3.9 V6 is the 5.2 or 5.9.
Only thing that can replace the 3.7 V6 is another 3.7 V6 unless you are electrically inclinded, then an 03/04/05 4.7 can be made to fit.
You may have the 3.9?, but 04 was the transition year I believe.
Old Jan 21, 2018 | 04:46 PM
oregun's Avatar
oregun
Thanks. Is there a combatible matrix I can consult? There also a 2002 with a bad 4.7L available locally. Would the same 2003 work in that?
Old Jan 21, 2018 | 07:22 PM
magnethead's Avatar
magnethead
Probably not. The 4.7 changed considerably in 2002/2003/2004 time range depending on the build date of the truck. Easiest way to tell, one generation has 3 connectors on the PCM (passenger engine bay fenderwell) and the other generation has 4. They're not compatible.
Old Jan 21, 2018 | 09:20 PM
00DakDan's Avatar
00DakDan
Section Moderator
The '04 should be the 3.7.
The 4.7 should bolt in, the motor mounts/front axle mounts may be different though. Like Magnet says, the engine needs to be from a 4 connector PCM, the NGC version, truck. '03 was the transition from JTEC to NGC.
Old Jan 21, 2018 | 09:46 PM
magnethead's Avatar
magnethead
I couldn't remember if the 3.9/3.7 transistion was 03-04 or 04-05. thanks. So many damn changes! haha
