97 dakota 2.5 5spd 2wd PO443
Old Feb 15, 2018 | 01:13 PM
DurdyGP's Avatar
DurdyGP
Default 97 dakota 2.5 5spd 2wd PO443
Ok i had PO204 i change the plug part of the fuel injection now i got PO443 i change the gas, an purge solenoid did a smoke test all good there i think its electrical but not sure ive had this truck since 99 never had this code pop up what gives i also read the evap run on the same circuit as another stuff with the truck but all my fues look good
Old Feb 15, 2018 | 09:27 PM
Open or short in the control circuit. If changing the valve didn't fix it, gotta check the wires.......
Old Feb 16, 2018 | 02:02 PM
DurdyGP's Avatar
DurdyGP
Thanks
Old Mar 8, 2018 | 06:33 PM
DurdyGP's Avatar
DurdyGP
Wiring is good changed my o2 sensors an the pcm
Old Mar 10, 2018 | 12:59 AM
DurdyGP's Avatar
DurdyGP
Default Seat belt wiring
So i got a broken seat belt wiring my dash light a the bell goes off but how do test this for a short This is the one i need to test its wierd its been unplug for year but only now going a code
