Best 1/4 mile times possible with 3.9 v6?
Old Mar 1, 2018 | 01:21 PM
  #21
magnethead's Avatar
magnethead
Originally Posted by tdcubbage
So Ryan gained 9hp and 14 lbs TQ with just the headers? Think that's a good gain. A guy once told me it cost $100 per horsepower so I guess that's great since headers go from $ 65-500. I really appreciate you guys information. Tell me this, are you saying that in my position you would skip every bolt on since they yeild no gain or a small one and jump right to the supercharger or nitrous?? Or would you agree that all these mods would complement each other well, maybe not on a NA motor but a boosted one??
The truck had been previously tuned by Ryan on manifolds. Corbin had ETM install the mid's and Ryan re-tuned it. So it was a fair assessment: headers gained 9/14 for the identical truck with only 1 change made.
The headers would likely be worth less on a stock tune before and after truck; meanwhile the gain would be more going from a stock tune/stock manifolds to headers with tune. Therein, why I mention that you have to know ALL the data. Not just some of it.
Old Mar 1, 2018 | 03:24 PM
  #22
tdcubbage's Avatar
tdcubbage
Yes the thread did start about the v6 but magnethead talked me into getting a v8. I said earlier that i had picked up a v8 for cheap and now any questions i ask will be pertaining to the v8. Sorry for the confusion. I will be selling my v6 to offset the cost of the v8. It should be here early next week.
Old Mar 1, 2018 | 04:18 PM
  #23
93 ragtop's Avatar
93 ragtop
Well good luck!! And I look forward to your updates! From others that I have talked to, (first gen forum) that have gone from the V6 to a V8 and especially the 5.9 were very happy....
I believe you will have a much easier time modifying the 5.2-5.9 vs the V6. There is just so little support for that V6 motor.
Old Mar 1, 2018 | 05:32 PM
  #24
tdcubbage's Avatar
tdcubbage
Thanks, im not sure if you know the answer to this or not but, the v8 came out of a 94 ram. Where i see most swaps are from dakota to dakota from 97-04. Its still a magnum v8. Do you know of anything that wouldnt be the same on the ram engine as a dakota? Ive been told rumors before of a different size oil pan???
Old Mar 1, 2018 | 10:09 PM
  #25
magnethead's Avatar
magnethead
Ram and Dakota use 2 different oil pans. 94 would be OBD1, i'm not sure about all the electronics.
Old Mar 2, 2018 | 06:13 AM
  #26
93 ragtop's Avatar
93 ragtop
The oil pan for the v8 is fairly cheap. http://www.rockauto.com/en/catalog/d...e,oil+pan,5562
As far as sensors goes, I dont know.
I have heard on 1st gen section, that everything will transfer over from your stock 3.9 to a 5.2-5.9. That the sensors and accessories are the same, for the most part. Most claim that you can use the stock harness and add the 2 additional injector wires to your v6 harness. But those are all but 96 model going to be OBD1 trucks. Yours may be different.
My swap is going a different way then yours. Mine is a 87 so it came with a carb. from the factory. I am going with a 5.9 and a 7577 Edelbrock intake, along with a 670 holley carb. Then adding a HEI ignition.
Im sorry, cant be of much help on the electronic side......
Old Mar 2, 2018 | 06:40 AM
  #27
tdcubbage's Avatar
tdcubbage
Do you think obdl might be beneficial to me, werent they alot less picky? Only had one 02 sensor? I know the pcm in my truck now is a picky sob. Always throwing a code for o2 sensors that are new. I thought about doing a carb swap once but of course ppl shot that down with the whys and what fors??? Saying EFI was always best, i dont know. And ragtop you asked earlier why i was trying to do both boost spray...my theory behind that was trying to build a fast truck on a budget. I was gonna leave the internals stock and not build it for boost or spray but in return i was only gonna run a safe 8lbs of boost with the blower all the time street and track. And then occasionally the 100 shot which is suppose to be safe on a factory engine. I dont like the idea of only nitrous simply because i like to have the power all the time, not just when i push a button. If i were to do only one it would be the SC. But yeah that was my logic hahah.
Old Mar 2, 2018 | 11:24 PM
  #28
magnethead's Avatar
magnethead
Depending on where you live, OBD2 is required to pass inspection.
You can swap all the sensors over. You'll have to wire in 2 new injectors to the PCM. I forget what year yours is, but 99 down should be EV1 connector and 00+ should be EV6/USCAR connector. Can get the pigtails online. Or just get a V8 donor harness from a 97-02 5.2/5.9 . You'll likely need a new PCM.
Old Mar 3, 2018 | 10:24 AM
  #29
tdcubbage's Avatar
tdcubbage
Thanks magnethead. I was going to get a obdl harness and computer. Ive heard talk of intake manifold differences? Something about egr? Do you know if that would matter if i was to buy a M1 intake...?
Old Mar 3, 2018 | 05:10 PM
  #30
tdcubbage's Avatar
tdcubbage
Or maybe a better question is, is it difficult to make a v8 from a obdl truck compatible with a obdll truck. Can i just swap any different sensors over to the obdl motor and it work fine with the obdll computer? The motors look identical but i know there was some differences.
