No AC in my 98 dakota
Old Apr 3, 2018 | 08:33 PM
Mike Krusto's Avatar
Mike Krusto
Default No AC in my 98 dakota
Hey guys i've searched the forum here for a fix but can't seem to find my exact situation. I've got a 98 dakota with a 5.2 and the AC hasnt worked since i bought the truck. I had the ac recharged and checked for leaks. Theres no leaks, I've also replaced the ac clutch relay but still cannot get the compressor to turn on. I can spin the compressor freely when the truck is off. I removed the relay with the truck off and jumped the terminals with a piece of wire and it caused the blower inside the truck to come on. Should that happen? I started up the truck and it still didnt turn the compressor. What else should i be checking to get this problem fixed??
Old Apr 3, 2018 | 08:40 PM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum.
Are you sure you jumped the correct relay? It should not cause the blower motor to run.
Try jumping the clutch directly off the battery.
Old Apr 3, 2018 | 10:40 PM
Mike Krusto
Yes it was the AC clutch relay. Number 26 I believe
Old Apr 3, 2018 | 11:38 PM
98DAKAZ's Avatar
98DAKAZ
Check the wire going to the clutch it may be severed inside the plastic but look OK happened to me if you giggled the clutch wire it kicked on and off.
Old Apr 3, 2018 | 11:57 PM
Mike Krusto
I've noticed that the clutch will engage for about one second then shut off for about 3 and repeat this cycle with the blower turned high and max AC on.
Old Apr 4, 2018 | 09:46 AM
00DakDan's Avatar
00DakDan
Section Moderator
That's likely the low pressure switch cutting off the compressor. Jump it and try it.
Then check pressures. You may have a leak in the system.
