Power steering pump
Old Dec 3, 2005 | 04:23 PM
$.99 Tacos's Avatar
$.99 Tacos
Default Power steering pump
[color=#3300FF][ Can anyone help??? Please! I have a power steering pump leak. So I went to AutoZone to purchase a re-man one. When I installed it, I tried to bleed the system and it didnt work. So I thought that it was a bad pump..returned it and bought another one. That did the same thing. I thought that I might of had the two valves and the spring in wrong order (valve-spring-valve.......spring valve-valve) so i tried both ways...nothing! I removed the return hose and I have flow but dont know if there is pressure. So I'm tempted to install the old one back on with new o-rings and live with the leak. Can anyone help??? I'm just stumped! Thanks!!!
Old Feb 22, 2006 | 03:49 AM
HUEY420's Avatar
HUEY420
Default RE: Power steering pump
never buy reman buy new
Old Sep 1, 2006 | 06:27 PM
360rango's Avatar
360rango
how did you go about bleeding the pump?
Old Sep 1, 2006 | 06:28 PM
360rango's Avatar
360rango
You must be doing it wrong for the pumps not to hold up
360rango's Avatar
360rango
your supposed to jack the front wheels up
360rango's Avatar
360rango
fill the pump up with fluid
360rango's Avatar
360rango
then turn the wheel lock to lock
Old Sep 1, 2006 | 06:29 PM
360rango's Avatar
360rango
30 to 40 times per direction
360rango's Avatar
360rango
when you no longer see air bubbles coming out of the fluid in the reservior
Old Sep 1, 2006 | 06:30 PM
360rango's Avatar
360rango
then you return the wheel to the center
