@003 4.7 replacement
Old May 26, 2018 | 11:28 PM
Atwood's Avatar
Atwood
Default @003 4.7 replacement
Hi. I have a 2003 4wd Dakota with a 4.7, CA vehicle that needs an engine replacement. May I replace this with ANY 4.7 from a 2000-2004 Dodge?
Old May 26, 2018 | 11:34 PM
magnethead's Avatar
magnethead
No. 2000 to 2002 are incompatiable, you can only use a 4.7 from 2003 or later...might also be limits on that (2003-2005 seems to be a window in my mind for some reason)
Old May 27, 2018 | 08:57 AM
Atwood's Avatar
Atwood
Thanks. So a 4.7 from a 2003 1500 Ram, which I have access to, should work in the 2003 Dakota?
Old May 27, 2018 | 09:55 AM
magnethead's Avatar
magnethead
You'll have to switch the oil pans and exhaust. Intake should be the same.
