Ok for the past couple of days my 01 4.7l dakota has been running fine but my temp gauge shoots right up to the first line on the gauge while the engine is still cold. This has never happened before and have no clue what would be cause this. Does anyone have any idea what i should check to find out what is causing this?
yea coolant levels i check first thing i thought of even open the allen bleed screw to see if there was any air in it. guess i will have to use my volt meter tomorrow to check the sender. is it measured in ohms or volts?
yes thx for the link but i ended up change the thermo and it didnt change then i changed the sensor and all good so i now have a new thermo and sensor. :P
