2004 4.7 Dakota turns off sometimes if I give it a little gas?
Old Jun 15, 2018 | 11:38 PM
SquareDorito's Avatar
SquareDorito
Default 2004 4.7 Dakota turns off sometimes if I give it a little gas?
So sometimes when I give the Dakota a little bit of throttle it will turn off on me. And by a little bit of gas I mean just a small tap so that I can back out of a parking spot. It will do this in reverse and in drive. The throttle body has been cleaned, wires are all good but I can't find a solution to this so far. It runs great if I just leave the throttle off for example when taking off from a red light, but it's those small taps that make it turn off, but only sometimes. I shift it back to park and it'll start right back up. Could it be the idle air control valve? I wanted to get a second opinion before changing it. Also, A/C doesn't really seem to make a difference as I have had it turn off with A/C on and A/C off. No CEL either. Any suggestions would be great. Thank you!
Old Jun 17, 2018 | 03:29 PM
magnethead's Avatar
magnethead
Does it die when you go into the throttle or come off?
Old Jun 17, 2018 | 03:31 PM
SquareDorito
When I come off throttle.
Old Jun 18, 2018 | 07:15 PM
magnethead's Avatar
magnethead
Idle Air Controller. It's likely hanging closed when you shut the blades, choking the engine out. The throttle body is easy to clean, and that's worth a try before replacing it since it idles normal otherwise.
Old Jun 18, 2018 | 07:18 PM
SquareDorito
I had already cleaned the throttle body. Changed the idle air control valve and she's working perfect now. Now if I can find out what's making that annoying squeak behind the steering wheel. Thank you
