Power Mirror and Power Door Lock Issues
Old Jul 31, 2018 | 02:10 AM
blue2002quadcab's Avatar
blue2002quadcab
Default Power Mirror and Power Door Lock Issues
okay electrical experts...here is an issue I am working on right now...
- 2002 dodge dakota quad cab
- power windows, power door locks, power mirrors
here is the issue.
- The Power door locks work fine with the remote key fobs however the door switches inside the truck will not lock or unlock the doors...
- the power windows and their switches all work fine on each door, the drivers door window controls all work fine
- the power mirrors do not work at all
Suggestions?
Old Sep 1, 2018 | 07:04 PM
EricBing's Avatar
EricBing
had the same issue on my 02 took out switch took apart switch slowly and carefully and cleaned contacts inside switch, under rocker switch for each corresponding for each function, My Ram has done the same thing, and my wifes dakota has done it too..I just used some rubbing alcohol on a Qtip one end to clean other end to dry....
