46re nss nightmare
Old Jan 26, 2020 | 06:55 PM
Jaynesr's Avatar
Jaynesr
Originally Posted by magnethead
I think trans goes in low gear, you compress the plunger, stab it in there, then run the screw in.
Meaning, I should drop it into low gear for it to go in...?...there is a green flourecsent ring in the way and I'm afraid to force it in ..
Old Jan 26, 2020 | 08:39 PM
magnethead's Avatar
magnethead
I believe that is correct. You want the gear selector in the position furthest away from the opening, so you don't have to compress the NSS as much. The spring in it is pretty strong and a pain to install. Fairly sure that's low gear position. Checking.
Old Jan 26, 2020 | 08:45 PM
magnethead's Avatar
magnethead
INSTALLATION
(1) Move the transmission manual shaft lever to the manual LOW position.
(2) Install the TRS mounting bracket into the transmission case. Using Adapter 8581 (Fig. 257), tighten the mounting bracket to 34 N·m (300 in.lbs.).
(3) Install the TRS (Fig. 258) into the mounting bracket with the wiring connector facing the front of the transmission.
(4) Install the two screws to hold the TRS to the mounting bracket. Tighten the screws to 3.4 N·m (30 in.lbs.).
(5) Verify proper sensor operation (Fig. 259).
(6) Move the transmission manual shaft lever to the PARK position.
(7) Connect TRS wiring connector to the TRS and lower vehicle.
(8) Refill the transmission fluid to the correct level.
Old Jan 26, 2020 | 11:04 PM
Jaynesr's Avatar
Jaynesr
Where can I see the figure pics your referring to..? 257 & 258
Old Jan 27, 2020 | 07:59 PM
magnethead's Avatar
magnethead
the mounting bracket is already in your case. The TRS only goes in one way, where the 2 bolts line up.
This is from the Factory Service Manual.
Old Aug 3, 2023 | 12:47 PM
Masonreg64's Avatar
Masonreg64
Originally Posted by Dumptruckbetty
01 Durango with 5 pin nss coming from harness the transmission has the 3 pin nss. Sonnex has adapter for the opposite scenario. School starts in less than a week and need to get truck going. Please any help will be appreciated.
we’re you able to find a fix? I am having the same issue
