Who has blocks in the rear?
Old Aug 8, 2018 | 08:51 PM
00t444e's Avatar
00t444e
Default Who has blocks in the rear?
I installed a set of 1.5" lift blocks in the rear, and when I went for a test drive I noticed the rear seemed to hop and bounce more that it did before, especially when I shift gears. I have checked the leaf spring and shackle bushings and they seem tight and I also checked the transmission mount and it seems fine as well, the only other thing I can think of is the shocks are worn out, or maybe it's the lift blocks causing this but I wouldn't think a 1.5" block would make much difference . Is anyone running lift blocks in the rear and having this issue?
Old Aug 8, 2018 | 09:28 PM
All the 2nd gen full sized trucks have blocks in the back..... May want to re-torque ubolts.....
Old Aug 8, 2018 | 09:33 PM
00t444e's Avatar
00t444e
Yes I am aware of that but I thought maybe the Dakota springs were to soft to handle a block and it's causing axle wrap, but like I said before its only a 1.5" which shouldn't make much of a difference, I usually retorque u bolts after 100 miles or so but I will go ahead and check these.
Old Aug 9, 2018 | 07:22 AM
You wouldn't think that that small of a block would have much effect..... any other changes to the rear suspension?
Old Oct 26, 2018 | 08:40 PM
00t444e's Avatar
00t444e
Update, the throwout bearing went bad so I put a new clutch kit and replaced the transmission mount and it's solid now.
