What did this go to
Old Aug 19, 2018 | 03:13 PM
hidden1's Avatar
hidden1
Default What did this go to
I found this in the tranny pan after loosing reverse.Drives forward ok an shifts ok.
What do these look like they went to?
Old Aug 19, 2018 | 03:33 PM
00t444e's Avatar
00t444e
Looks like a snap ring that retains one of the clutch packs.
Old Aug 20, 2018 | 12:05 PM
hidden1's Avatar
hidden1
Is this why nothing happens when I shift to reverse,it's automatic 6 cyl 3.9?
Has that broken clip caused overdrive clutch pack to move or not enguage in reverse?..
There is a slight wine in low gear too.
Can I pull the overdrive without dropping tranny fully.?
Old Aug 20, 2018 | 12:07 PM
00t444e's Avatar
00t444e
Yes that could be the issue, I am pretty sure you can pull the overdrive housing off with the transmission still in, I just did that to a 47RE not to long ago.
Old Aug 20, 2018 | 10:18 PM
magnethead's Avatar
magnethead
Overdrive auxbox shouldn't affect reverse. It's probably the retainer for the reverse primary clutch.
