ATF+3 substitute?
Old Aug 20, 2018 | 02:12 PM
restlessswind's Avatar
restlessswind
Default ATF+3 substitute?
Ok,I am wanting to drain and fill the transmission pan. I have read that ATF+3 is the required fluid, and not to use ATF+4.
Well, it seems tat +3 no longer exists. Suggestions? Am I missing something?
Old Aug 20, 2018 | 03:23 PM
What vehicle are you referring to?
Old Aug 20, 2018 | 09:03 PM
Why would they NOT recommend using a better fluid?????
Old Aug 20, 2018 | 09:40 PM
primem's Avatar
primem
+4 should be backwards compatible...read it here...
https://www.centerforqa.com/chrysler-faq/
Old Aug 21, 2018 | 12:17 PM
restlessswind
Thanks, I'll just use the +4. Just wondering is all. I read that the +4 is synthetic, and the +3 isn't, and shouldn't mix. I was looking for clarification. I seem to think you all helped me. Big thanks!
