I have a 2002 Dakota Quad 4WD with the 4.7 engine. I think I have a transmission line leaking and want to make sure of my repair idea.
There are two steel lines running along the passenger side of the transmission. They are running about in inch apart from each other and joined with a plastic clip. Right at the plastic clip there is a leak when running.
Can I cut the leaking section out and use fuel line and clamps to repair?
