p0132
Old Sep 30, 2018 | 08:15 PM
dc1955's Avatar
dc1955
Default p0132
Hello, I have a 2001 Dakota 4.7 Cali emissions(2 cats-4 02 sensors). Changed both cats and all 02's, TPS, Map, and IAC and I am getting a rpm surge while driving 35-40 mph up 500rpm then down 1000 then back up. Every once and a while at a stop or slow down truck will die but start back up. Also at times its seems that there is no response from the throttle, like a dead spot until you punch it to the floor. I also must mention it seems all this started when the left side speakers cut out, which come and go. Am I looking for a loose or bad ground?
Old Oct 1, 2018 | 04:35 PM
Code is for bank one O2 sensor. (pre-cat.) Voltage high. It's likely shorted to the heater circuit. Would that cause your issues? Maybe...... replace the sensor, see what happens.
Old Oct 1, 2018 | 05:09 PM
dc1955's Avatar
dc1955
@HeyYou, Thanks for the quick reply, as I said all the sensors are new(Denso) along with the cats. Stalling when coming to a stop or a slow down has stopped but the rpm surge is still there mostly around 1500-1700 rpm but its not constant. I can drive around for awhile and its seems fine then out of the blue it will surge. Is it possible there could be a problem with the shift solenoid? I'm not pulling any codes at all at the moment. Beginning to think the only solution will be a gallon of gas and a match!
Old Oct 1, 2018 | 08:57 PM
Would be interesting to data log some, and see if the surge coincides with the sensor freaking out..... I doubt you got a second sensor with the same problem..... (though, it IS possible.....) time to check the wiring for the sensor.
Old Oct 1, 2018 | 09:19 PM
magnethead's Avatar
magnethead
Hmm..Denso....JTEC is programmed for NGK...so Denso may or may not be out of range. (Same applies with Bosch)....
Old Oct 2, 2018 | 07:20 AM
dc1955's Avatar
dc1955
Got the wiring diagrams last night, so it looks like I'll be wire tracing today. Keep you posted, again thanks for the help.
