Ac Blows Strong Through Middle Vents Only
Old Nov 26, 2018 | 02:52 PM
Jordan PJ's Avatar
Jordan PJ
Default Ac Blows Strong Through Middle Vents Only
Hey everyone! Has anyone had the issue where the ac would blow strong through the middle vents and very soft through the side vents? The blower motor seems to be fine and I’ve cleaned the dust and debris out from it. I recently replace the blower motor resistor and the little dirt above the blower motor is also working fine. I’m not sure where else to check if those vents might be clogged up? Any help would be appreciated thank you!
Old Nov 26, 2018 | 10:29 PM
magnethead's Avatar
magnethead
I think that's fairly typical due to restrictive ducting inside the dash. I could be wrong.
Old Nov 27, 2018 | 09:48 AM
Yeah, if you want more airflow from the sides, close one of the center vents.
Old Nov 28, 2018 | 01:22 PM
Jordan PJ's Avatar
Jordan PJ
Thanks for the reply! At least I know now lol
Old Nov 28, 2018 | 01:23 PM
Jordan PJ's Avatar
Jordan PJ
Thanks for the suggestion I’ll give that a try
Old Nov 28, 2018 | 06:15 PM
hidden1's Avatar
hidden1
It may sound odd but I got more airflow after flushing out the heater core on mine..
my side vents are stronger in air flow than the middle vents though.
