99 dakota limp mode problem
Old Dec 12, 2018 | 12:46 PM
Dmarcum's Avatar
Dmarcum
Default 99 dakota limp mode problem
Hi everyone, I have a 99 dakota sport 4x4 with the 3.9 auto. It is stuck in limp mode and I am starting my diagnosis. I have checked fuses and am moving to the TCM to check for proper power and ground, but reading other posts it says to check pin 56 for power, my tcm has 3 plugs, each numbered to 31. I am hoping someone can ID the pin that I need to check on this TCM. Thanks in advance.
Old Dec 12, 2018 | 02:03 PM
Move to the correct section. Had it scanned for codes?
Old Dec 12, 2018 | 03:24 PM
Dmarcum's Avatar
Dmarcum
what is the correct section? No codes, but Im just using a obd2 scanner.
Old Dec 12, 2018 | 07:01 PM
XSubaruJeepDude's Avatar
XSubaruJeepDude
A bad TPS has been reported to cause this sometimes.
Old Dec 12, 2018 | 09:48 PM
magnethead's Avatar
magnethead
Dakotas did not have a dedicated TCM until the 4.7/545RFE combination came around, I believe 2003 . Until then, all transmission control was done through the powertrain control module, which had the 3 connectors.
How do you know it is in limp mode? I do not recall the early PCM's having that feature.
Old Dec 13, 2018 | 09:55 AM
You likely have the 42RE trans, or maybe a 44RE.
Just what symptoms are you experiencing? Does it not want to shift? Shift too late/early??
Old Dec 13, 2018 | 10:19 AM
The correct section is this one. 2nd gen Dakota technical section.
