Help 42RLE Transmssion stuck in reverse.
I have a 2004 Dakota 4x4 with a 3.7L and about 147k on it. I started my truck and when I went to put the truck into drive, the shifter only went down to reverse and now the truck won’t come out of reverse. I have never had any transmission trouble with this truck; I know the ATF level is right where it should be, because I had just checked all the fluids about a week earlier. I thought maybe the shifter cable was bad, but I went under the truck and pulled the cable off and it slides in and out with no problem. I then tried to move the linkage by hand and it would not budge. I need this truck running, so I would really appreciate any suggestions. Thank You and Merry Christmas.
When i had to replace my overdrive i was in junkyard an took off the valve body on one that was off ,here is a pic of that rod with a spring in it that is attached ,not in pic now, to the rooster or holder in valve body pic -- that arm with the spring on it ..
maybe it came off . 3rd pic hole is where it went
Last pic is where rod continues on ,to link in at reverse/overdrive.
Thank you for sharing those pictures.I decided to pull the pan and valvebody, I found a really good video that shows the rooster comb. I can't see it being anything else, because this tranny has never given me any trouble before. I have afew days to play before I head back out on the road.
