ABS, BRAKE light on and no speedometer.
Old Dec 31, 2018 | 01:04 PM
Kenneth J Owens Jr's Avatar
Kenneth J Owens Jr
Default ABS, BRAKE light on and no speedometer.
Anyone have this problem with their 2002 dakota with a 4.7? Checked all the diagnostic procedures and everything is within the parameters, wondering if the PCM needs to be reprogrammed. Any info on this issue would be greatly appreciated.
Old Dec 31, 2018 | 02:34 PM
Skreelink's Avatar
Skreelink
I had the same problem on my 1998 Dakota 3.9L. The speedometer did work over about 35, the problem was the ABS/Speed sensor ontop of the rear differential. However, I think the 4.7L's 45rfe has it on the tailshaft of the transmission. Crawl under and see if you have a wire and sensor ontop of the rear differential, if you do, that's likely it.
Old Dec 31, 2018 | 04:37 PM
Kenneth J Owens Jr
I replaced that and the vehicle speed sensor and still not working
Old Dec 31, 2018 | 04:54 PM
Skreelink's Avatar
Skreelink
Might be a wiring problem, see if there's a reference voltage at the rear sensor with a multimeter.
Old Jan 1, 2019 | 11:29 AM
hidden1's Avatar
hidden1
Would be good idea to check for the ABS codes .an any pending regular codes.
High end free rent tool can read it .
