97 dak 3.9 AT 4X4
Old Jan 7, 2019 | 10:07 AM
rlhs's Avatar
rlhs
Default 97 dak 3.9 AT 4X4
2 drivability issues, possibly related?
1st: occasional pop and sputter, usually on acceleration
2nd: occasionally sputters and stalls on braking, usually coming to a stop. Has now progressed to the point that it won't go much of anywhere. Crank for a while before it will start, then runs fine in particular or neutral, won't go 20 feet once it's in gear.
Daily driver, this problem started about a month ago.
Old Jan 7, 2019 | 10:40 AM
Plugs, wires, fuel filter, fuel pump, vacuum leak, etc. Had it scanned for codes?
Old Jan 7, 2019 | 03:38 PM
magnethead's Avatar
magnethead
sounds crank sensory
Old Jan 7, 2019 | 03:50 PM
rlhs's Avatar
rlhs
Default 97 dak
Typically, plugs, wires, fuel filter, would all be relatively constant, where this has been intermittent. Before yesterday, I might drive to and from work (13 miles each way) without a problem. Fuel pump might be sporadic, really don't wanna drop tank without knowing that's the problem. Hoping to get codes scanned tomorrow.
