Front Drive shaft interchange
Old Mar 8, 2019 | 10:40 AM
alanamaclean's Avatar
alanamaclean
Default Front Drive shaft interchange
Need a new front drive shaft for a 99 Dakota 4wd club cab (double cardone style with u joints on both ends)
Its got an 01 Dakota t-case (np231) that has the same ujoint on the front driveshaft as the original.
Cant find any used Dakota driveshafts that'll work. Anyone know what driveshafts are interchangeable?
Old Mar 8, 2019 | 11:20 AM
Can you get the old shaft rebuilt?
Old Mar 8, 2019 | 11:29 AM
alanamaclean
To an extent...drive shaft itself is fine.
The seat for the ball joint in the double cardone is in bad shape..would need a new one and need a new ball kit. Used driveshafts are goin for $40 at the upick...that one piece new theyre looking for $300.
Old Mar 8, 2019 | 11:39 AM
Ouch. I would be tempted to see what it would take to convert it to use the CV joint at the t-case end..... I suspect it would just require replacing the front output flange on the t-case.
Old Mar 8, 2019 | 12:29 PM
alanamaclean
Not a bad idea.. will have to see if it is just as easy as unbolting the ujoint attachment and throwing a flange on er.
