hard steering
Old Dec 12, 2005 | 02:00 AM
dakotaboy's Avatar
dakotaboy
Default hard steering
i drive a '00 dakota sport 4X4 4.7 V8 and i have noticed that if i don't drive it for a day or so and the weather is real cold outside, then when i get in to drive it, it is difficult to steer at first but after a couple of turns, i don't even notice it anymore. like i said, i have only noticed this is when it is real cold outside. what do you guys think i should do?
Old Dec 12, 2005 | 03:00 AM
Natedogg625's Avatar
Natedogg625
Default RE: hard steering
I have the same problem but its because the power steering fluid hasn't circulated completley yet. No big deal
Old Dec 12, 2005 | 03:01 AM
kdh97602's Avatar
kdh97602
If no one has said it to you yet, welcome! There are few reasons to have the fluid changed or even flushed out of a PS system, you may have one. Check your fluid, if it looks like crud - change it, just cap off the return at the pump and have the return line go down to a catch basin (like the one you would use to change your oil), start the truck (preferablly have your buddy do that), and refill with new fluid. When i got my truck, it was driven hard (was owned by So. Cal. edison) and I had the same problem, untill i changed my fluid. If the fluid change doesn't help, and there was A LOT of crud in the PS system, it needs to be flushed, flush kits are avalable at my local autoparts store (so i think they would be avalable to you too) just follow the instructions. If the fluid is or looks good - ??? good luck!
Old Dec 21, 2005 | 09:49 AM
sdsdsd's Avatar
sdsdsd
Could be a sign of the PS rack going bad.
