2000 dakota 9" to 11" rear drums upgrade
Old Apr 9, 2019 | 09:16 AM
Mopar44134's Avatar
Mopar44134
Default 2000 dakota 9" to 11" rear drums upgrade
I picked up a 2002 Durango. its totaled but it still drives. I pulled the drivetrain, 4.7 4x4 non lsd rear end. i pulled off a bunch of other odd ball stuff, pcm, tcm, door switches, radio, instrument cluster etc.
Before it goes to the scrap yard i was wondering if swapping the backing plates from the durango to the dakota, and adding new 11" shoes, hardware, wheel cylinders and drums is all i need to do for the bigger brakes. Thanks!
Old Apr 10, 2019 | 12:04 PM
00DakDan's Avatar
00DakDan
Section Moderator
Yes that's all you'd need for the hardware install.
One thing to consider is that the proportioning valve in your truck is set up for the 9" brakes. The antilock should keep the rears from locking up but you might notice a difference.
The front brakes do most of the work when stopping.
Old Apr 11, 2019 | 08:48 AM
Mopar44134's Avatar
Mopar44134
Thanks, Since i still have the durango...might as well take that too.
Old Oct 23, 2022 | 10:54 AM
E7018's Avatar
E7018
Default Ok same question about the backing plate swap
Does this work with both differential sizes? We have the 9" brakes on the smaller differential,2000 Dakota with the ten bolt cover would like to swap in the elevens if possible
Thanks
Old Oct 23, 2022 | 12:33 PM
supadoom's Avatar
supadoom
Should. The axel ends are identical.
