45rfe park to reverse clunk and buzz
Old Apr 24, 2019 | 06:56 PM
n00bdakowner's Avatar
n00bdakowner
Default 45rfe park to reverse clunk and buzz
had the front end up for engine oil and filter change. after the transmission makes a clunk and buzz from park to reverse and again from reverse to park. that is the best i can descried it. the main reason for buying this truck is the transmission didn't make noises and the fluid looked good. the clunk makes me think u-joints or rear end but, then there is some kind of buzz that makes me think computer.
anyone else have had this?
Old Apr 24, 2019 | 10:57 PM
magnethead's Avatar
magnethead
Just for grins and giggles, pull the inspection cover and check the converter bolts. They'll usually make a rattle sound, but it could be mis-heard as a light buzz.
Old Apr 25, 2019 | 08:28 AM
Dodgevity's Avatar
Dodgevity
The clunk, not so much, but the buzz is probably normal. Mine does it every time and it lasts roughly a second.
Old May 2, 2019 | 09:55 PM
n00bdakowner
had someone shifting it for me while peeking under the truck and could have swore the clunking was coming from the transmission. sitting in the cab i am convinced it is the rear end and will check the backlash soon. not use to a buzz coming from the transmission.
thank you
Old May 7, 2019 | 02:06 PM
Zingo's Avatar
Zingo
Both of my trucks had perfectly fine transmission that never had problems and they both make the "buzz" you are more than likely talking about for just a second after shifting.
I would be most suspicious of the transfer case (assuming you have a 4x4) if the sound is coming from that area and you're sure it's not u joints.
But how big of a clunk is it anyways? Are you maybe just a little paranoid? I get like that sometimes.
