Where is my oil going?
Old Aug 6, 2019 | 07:40 PM
Originally Posted by hidden1
Great to hear.
But how did the oil pressure guage switch cause so much oil to be lost ? Or burned up so fast.?
It leaks out the sensor, and then basically is burned off on the hot engine, before it makes it to the ground.
Old Aug 6, 2019 | 09:18 PM
hidden1's Avatar
hidden1
Ah. Yes
Oil sensor .
Where is that at exactly..I want to look at mine ..
Old Aug 6, 2019 | 10:09 PM
What engine?
Old Aug 7, 2019 | 12:05 PM
hidden1's Avatar
hidden1
3.9 6 cyl automatic
Old Aug 7, 2019 | 12:08 PM
Back of the block, just to the passenger side of the distributor.
Old Aug 7, 2019 | 02:53 PM
Dodgevity's Avatar
Dodgevity
Not with the 4.7. The pressure switch is underneath next to the oil filter, so it would be hitting the ground.
Old Aug 8, 2019 | 11:02 AM
Sensor on my 8.0 is in the same place. Makes it MUCH easier to work on, and it would also be patently obvious if it were leaking, and if it were, it would indeed show a puddle, or at least spots, on the ground....
Old Aug 8, 2019 | 12:50 PM
hidden1's Avatar
hidden1
Yea it would leave a lot!
Maybe his is where mine is . By distributor.
I still cant see how that much gone that fast wouldnt show so.something..or a smell of it burning
Old Aug 8, 2019 | 03:54 PM
My 96 would burn through a quart every 150 miles or so. Nothing on the ground, no blue smoke, just a light puff at startup after it had been sitting for a while. (day or more.) No clue where it was going.....
Old Aug 11, 2019 | 11:31 PM
harkdodge's Avatar
harkdodge
Great to hear.
I'm still at a loss as to where my oil was going. I read where a severely dirty air filter or a bad PCV valve would cause drastic oil loss so I changed my PCV valve and cleaned my K&N air filter. I found no oil in the air filter box and the PCV valve was very dirty but still rattled.
I thought possibly it was a leaking oil pressure gauge switch but I found no evidence of leaking oil around it when I was changing it out.
I'm continuing to watch my oil level and will check it daily until I am satisfied the problem has been remedied.
