03 3.9 to 5.9 4x4 quad cab
Old Aug 7, 2019 | 04:16 PM
Aaron H's Avatar
Aaron H
Default 03 3.9 to 5.9 4x4 quad cab
What motor mounts do i use? will 3.9 4x4 motor mounts work? or should i use 5.9 4x4 mounts? asking because they’re different part numbers and also they don’t sell the brackets for the 5.9 where i am
Old Aug 7, 2019 | 09:30 PM
magnethead's Avatar
magnethead
Order a set of poly mounts from Richard at HiPoTek. You'll be glad you did. His should work for both 2wd and 4wd. His are what I am using for my 3.9/408 swap.
Old Aug 7, 2019 | 09:45 PM
Aaron H's Avatar
Aaron H
Okay i will take your word for it, ill let you know how it goes
Old Aug 8, 2019 | 09:53 AM
magnethead's Avatar
magnethead
Well shoot. His website says RWD. IDK how much the 4x4 is different (i thought the diff strap went to the block). You may have to go junkyard hunting.
Old Aug 8, 2019 | 10:49 AM
Aaron H's Avatar
Aaron H
I have a parts car same year durango rt 5.9 i was just trying to avoid the hassle of getting them, plus i wanted new ones so i don’t have to worry about ever changing them. But i took a look at that website last night and i noticed the same thing, i emailed them just to see
