Question about CPS
Old Aug 12, 2019 | 05:23 PM
Dakine85's Avatar
Dakine85
Default Question about CPS
I was wondering what year they went from 16 tooth CPS to the 32 tooth. The reason I ask is because come to find out I have a dak that was made in 10/02 with a 2001 wire harness with a 32 tooth CPS with a 38 pin lay out for the PCM
Old Aug 12, 2019 | 08:30 PM
magnethead's Avatar
magnethead
I thought 00/01/02 was 16 tooth/3 connector JTEC and 03+ was 32 tooth/4 connector NGC.
Maybe it was 00/01 and 02+.
3 connector JTEC should be 3 connectors of 32 pins IIRC
4 connector JTEC should be 4 connectors of 38 pins IIRC
Old Aug 12, 2019 | 09:18 PM
Dakine85's Avatar
Dakine85
Matches a 2001 wire diagram
Matches a 2003 but colors and pin lay out doesn’t
Old Aug 12, 2019 | 09:58 PM
magnethead's Avatar
magnethead
Does it run? Did you just buy it?
Looks like they got 3/4 way through an engine swap and realized they made a royal F'up...
The PDC should be pretty much the same for all years. Only the PCM and engine harness changed.
Old Aug 12, 2019 | 10:04 PM
Dakine85's Avatar
Dakine85
It runs like a top and drives good also when I got it it had a blown motor rebuilt that. I decoded the vin and it says it’s a 03 sport with a v8. All the wiring is intact nothing has been spliced into
Old Aug 13, 2019 | 11:02 PM
magnethead's Avatar
magnethead
That's....umm....wild.
