Load distributing hitch
Old Aug 28, 2019 | 08:59 AM
Dodgevity's Avatar
Dodgevity
Originally Posted by magnethead
Oh boy. Just an FYI...you're looking to tow something that weighs the same if not more than the towing vehicle....Brakes will be your #1 issue.
Originally Posted by truckpro
Although if you do have great brakes and you are confident in pulling a heavy load, then a weight distribution hitch is the way to go.
With that much weight, you want to make sure you have a brake controller unless the trailer has surge brakes. I've seen them both ways. You may have a place on the wiring harness somewhere where you can just plug into the electrical system.
^^^ This ^^^
You should never rely on your vehicles brakes to stop a heavy tow load, great brakes or not. Your trailer should have it's own brakes, activated by a controller. You can set the braking force with the controller and if you overdo it, it can stop so well that it will yank your vehicle back.
Old Aug 28, 2019 | 09:33 PM
magnethead's Avatar
magnethead
^^^ This ^^^
Even with trailer brakes, the vehicle brakes can only do so much.
We roll along at probably 14,00-15,000ish pounds with 6 brakes on the trailer and 4 on the truck. The Tekonsha P3 is accelerometer-controlled controller, and I have it on the highest boost setting and pretty high power - it pretty much goes straight to 9+ volts under braking, plus the duramax has an engine brake in tow/haul mode. Even with all that going on, it's a female dog to get stopped from highway speed.
