Emissions swap? Lol
Old Aug 17, 2019 | 12:17 PM
Aaron H's Avatar
Aaron H
Default Emissions swap? Lol
Hello, i’m currently in the process of doing a 3.9 to 5.9 swap on an 03 dakota sxt, it is pretty basic but i’ve ran into a couple problems. My truck that is getting the 5.9 is california emissions, now my parts car is a 03 durango rt federal emissions. My question is, if i have the federal emissions wiring harness, Ecu, and exhaust (1 cat vs the 3 on cali) even tho i’d rather run no cats, this should work right? I live in new york so i’m not worried about getting caught or anything stupid like that. Only reason i ask is because dick head at advance auto won’t sell me federal emissions y pipe with cat on it, he says he’ll get fined and that a federal emissions cat will blow up my 5.9? LOL part store workers man
Old Aug 17, 2019 | 12:30 PM
primem's Avatar
primem
you will have po420 p0430 codes setting due to no cats. nothing will blow up! go to another store and buy whatever exhaust you want.
You: I need a federal emission y pipe for a 03 dakota
jobber: sold
Old Aug 17, 2019 | 12:35 PM
Aaron H's Avatar
Aaron H
jobber: sold
But if i use the federal emissions y pipe with the cat i shouldn’t have any codes right? haha i’m gunna go to napa and see what they have
Old Aug 17, 2019 | 12:42 PM
primem's Avatar
primem
if have the fed wiring harness, fed pcm..and there is a cat and the pcm is only looking for 1 post cat 02 sensor you should be good.
Old Aug 17, 2019 | 12:44 PM
Aaron H's Avatar
Aaron H
Okay that’s what i thought i’m just double checking with you guys, thanks very much
Old Aug 17, 2019 | 01:33 PM
magnethead's Avatar
magnethead
You can fool it however you'd like. My method was to remove the 2 mini-cats, leave the third main cat, then use O2 extensions to relocate the two downstream sensors behind the main cat.
Old Aug 17, 2019 | 01:37 PM
Aaron H's Avatar
Aaron H
That’s not a bad idea if i were to have a california wiring harness, but wouldn’t that also run a code? I feel like the littlest change on those things would **** everything up
Old Aug 17, 2019 | 03:59 PM
magnethead's Avatar
magnethead
My truck is a california truck, but I took the pre-cats out so functionally it's a federal truck, but electrically it's still Cali. No codes - Since the downstreams still sense a "cleaned" signal from the main cat, they are happy.
Since you're switching the engine harness instead of just adding injectors 7 and 8 to the V6 harness (what I did, staying with Cali PCM), since the PCM and harness will both be federal, then you should just need to put the O2's in their appropriate place, before/after the main cat.
If you want an extra play...you can just swap the Y pipe from your donor truck, unless you had to cut it out? Exhaust manifolds and pipes are in the same place on V8 and V6.
