1997 dakota 2WD transmission issue
Old Aug 23, 2019 | 06:14 PM
fernandog's Avatar
fernandog
Default 1997 dakota 2WD transmission issue
I have a 1997 Dodge Dakota automatic 2WD 6cyl. Last week it stopped shifting into higher gears. Stays in 1st and will not shift up. Fluid is clean and filter was changed just 9 months ago. I changed transmission output speed sensor. Didn't help. Any ideas anyone ?
Old Jan 12, 2020 | 12:53 PM
cheddarlaw's Avatar
cheddarlaw
Are you low on fuel? Ive heard that the late 90s dodge trucks sometimes will not shift if low on gas. Otherwise you might need to look into a new valve body. You can find them used with a quick google search
Old Jan 12, 2020 | 08:08 PM
magnethead's Avatar
magnethead
drop the pan. You've got large chunks laying in there that belong a little further up. If you have an inch-pound torque wrench, it's a free fix in your driveway. Slide the strap back in place and tighten the adjuster stud.
