Replacing Speaker, 2001 Dakota Quadcab
Old Sep 25, 2019 | 09:43 AM
John_N's Avatar
John_N
Default Replacing Speaker, 2001 Dakota Quadcab
The woofer in the driver side of my Dakota is disintegrating. There was a paper decal on the back of the speaker that is also destroyed, and I could not make out any specs on it (ohms, watts, etc). Read somewhere that the stock Infinity amp in these trucks support 2 ohm speakers (vs 4-8 ohms), is that correct, or do I have to locate and extract the amp to make sure?
Also, I see the stock Infinity speaker has 3 mounting tabs instead of the usual 4; does that mean special modifications to get an after-market speaker to fit?
Old Sep 25, 2019 | 03:26 PM
NullPointer's Avatar
NullPointer
Can just replace the foams for cheap if interested. I did all mine years ago, still sounding great. https://dodgeforum.com/forum/2nd-gen...ml#post2917531
Old Sep 25, 2019 | 07:39 PM
Dodgevity's Avatar
Dodgevity
The speakers are still being sold....
https://www.moparpartsoverstock.com/...0aAgz6EALw_wcB
I threw all mine away when I upgraded years back. You might find them in junkyards too, but these are one of the few parts aftermarket makes better. Sky's the limit.
Old Sep 25, 2019 | 11:40 PM
magnethead's Avatar
magnethead
aftermarket speakers from crutchfield will include the 3 to 4 tab adapter if you use the what-fits tool, some 6.5's come with both mounting options cast into the basket.
If you have separate tweeters on the doors up by the outside mirror, then you have infinity.
