fuel issue (i think)
Old Sep 30, 2019 | 07:51 AM
wheily's Avatar
wheily
ya the cat was removed before i bought it and i installed an anti fowler to get o2 out of exsaust stream so it would stop throwing a code for it
Old Oct 3, 2019 | 03:07 AM
wheily's Avatar
wheily
finally got a fuel pressure gauge now just got to wait for my day off
Old Oct 3, 2019 | 09:09 AM
ol' grouch's Avatar
ol' grouch
Originally Posted by wheily
yes still has what ever censors were in it when i bought truck...the tps censor is about 2 months old not sure the brand i picked up a fuel pressure tester on my way to work last night so i can atleast see if it is a pressure problem but wont be able to check when driving as if it it starts stalling out worse i wont be able to get it up the mountain to house .....thanks for all the advice so far
I don't know if I would have bought a truck with a potty mouth. Why else would it need to be censored?
Seriously, when I saw you have trouble getting up a mountain, I'm thinking something other than fuel is your problem. In an earlier post, I asked if it was pulling good vacuum. The reason for that was if it sat for a while, mice may have made a nest in the muffler or it may have rusted inside and collapsed. This will plug you up like too much cheese. When I reread the original post, where you said it had 145,000 miles, the penny dropped (2 actually, inflation you know ) I'll bet dollars to donuts your timing chain was loose enough to jump a tooth. Chrysler's engines, at least the older ones, will run with a jumped tooth. They will NOT have any power. I had a '54 Dodge with the 241 Hemi years ago. When it jumped time, it ran just fine. It could barely get over a hill to get home. A 241 Hemi had plenty of power for the day and could really scoot.
Check both fuel and vacuum pressure. However, listen to your timing cover. I'll bet there's a shika-shika-shika sound coming from it. All these parts being thrown at the truck won't fix that. You'll probably need to replace the timing set. There is also an updated timing tensioner that came out in the late 90's. Replacing this will really wake your truck up. I've gotten many vehicles through the years that the previous owner got tired of fooling with and many times it was a timing issue.
Make sure it IS a timing chain issue. If it is, replacing it will give you more power, better fuel economy and the heater will probably run you out.
Old Oct 4, 2019 | 05:53 AM
wheily's Avatar
wheily
timing chain gears and tenshoner was just replaced about 4 weeks before i started having the drive ability issue ...also what i mint about not gatting up the mountain is its a 1 lane road up a mountain to my house and if it stalls or wont run long enough to get up the hill then id have to leave truck at bottom witch is roughly a mile away ..i will check the vacum when i get a chance to work on it this weekend ....thanks for the advice..
Old Oct 4, 2019 | 10:08 AM
ol' grouch's Avatar
ol' grouch
Do you have feral cats around your house? I see you're in the NorthWest and it's been cool there. If you don't have cats, mice may have built a nest in your exhaust. Usually when a vehicle sits for a while but I've seen them do it over night. Look for a little mouse with a uniform. (A door mouse. ) Seriously, a vacuum reading will tell you where to track the problem down at.
I love the OBD II systems but I still use my wooden stick, volt/ohm meter and vacuum gauge to track down problems. I've just added a code reader to the mix. (Yes, I did say wooden stick.)
Old Oct 4, 2019 | 03:56 PM
wheily's Avatar
wheily
well i cant find my vacum gauge (figures) i do have a small vac leak between booster and brake master cylinder.. but i checked fuel pressure at idle and its at 50 psi but if you rev up the engine it drops to 25 psi so im gessing my new fuel pump is junk gess i shoulnd have got it online as warrenty will be a pain ..
Old Oct 4, 2019 | 06:18 PM
magnethead's Avatar
magnethead
yea if it drops to 25 under flow then you've got an issue. Should hold about 52 pounds at all times.
Old Oct 4, 2019 | 07:19 PM
wheily's Avatar
wheily
well i ordered another pump this time its a delphi ....on the plus side every thing was just out so wont have to fight the bolts this time
Old Oct 5, 2019 | 10:31 AM
ol' grouch's Avatar
ol' grouch
You think. I've learned that Murphy will raise legal objections at times. At least you now have experience and that speed things up.
Old Oct 5, 2019 | 02:41 PM
Murphy was an optimist.
