Help! How do i drain the fuel in the tank? I depressurized using the Schroeder valve
Old Oct 16, 2019 | 03:22 PM
Lawrence Edward Muir's Avatar
Default Help! How do i drain the fuel in the tank? I depressurized using the Schroeder valve
I'm having trouble emptying the fuel out of my fuel tank I don't have the tools or the lifts to drop the tank so I thought if I under the fuel line and put a hose on the end of it which I have done if I turn the key it would just drain the fuel in the tank through the fuel line Am I Wrong am I missing something?
Old Oct 16, 2019 | 08:51 PM
Pump will only run for about 3 seconds once you turn the key. Best bet is to just jump the fuel pump relay, so the pump runs 100%. Pin 30 to pin 87 (or 86?) Terminals are labeled on the bottom of the relay, usually.
