Hi beam problem 98 Dakota
Old Oct 18, 2019 | 10:53 AM
bushhog69's Avatar
bushhog69
Default Hi beam problem 98 Dakota
My hi beams only work if I hold the turn signal lever back, when I let go they go back to lo beam. I have tried two different multi function switches and that is not what's wrong with it. What do I look for? Thanks
Old Oct 18, 2019 | 01:57 PM
ol' grouch's Avatar
ol' grouch
Was one of the ones you tried a new one? If not, you probably have two bad ones.
Old Oct 18, 2019 | 05:32 PM
bushhog69's Avatar
bushhog69
Both new, one from parts store the other from Dodge
Old Oct 18, 2019 | 07:48 PM
magnethead's Avatar
magnethead
I don't have a 98 manual, but i believe those are direct wired instead of through a module.
Odd that flash-to-pass is working but not the high beams. I'd check the relays first.
Old Oct 19, 2019 | 12:00 PM
bushhog69's Avatar
bushhog69
I'll check them. Thanks
Old Oct 19, 2019 | 03:00 PM
00DakDan's Avatar
00DakDan
Section Moderator
They are direct wired. The headlamps should always be hot with the ground side switched.
