2001 Parking Brake Tensioner (part #52009868AF)
Old Oct 31, 2019 | 03:45 PM
ejsant's Avatar
ejsant
Default 2001 Parking Brake Tensioner (part #52009868AF)
The parking brake tensioner broke last evening as I set the parking brake. The OEM part has been discontinued and I cannot find an aftermarket part. Other then a junk yard are there any other suggestions? My research hasn't turned up a suitable replacement. Thank you all in advance for your assistance.
Old Oct 31, 2019 | 11:30 PM
magnethead's Avatar
magnethead
just the junkyard more than likely. And the northern ones will be rusted to bits, probably like yours was (I'm guessing).
Old Nov 1, 2019 | 09:40 AM
NullPointer's Avatar
NullPointer
Go check out the Dorman replacement part aisle at local parts store (or web site). They have tons of universal parking brake connector/adapter stuff that can probably get you up and going again for couple bucks. Not an OE solution, but better than truck rolling away.
Old Nov 1, 2019 | 01:02 PM
ejsant's Avatar
ejsant
Thank you both. I believe I found an older version of the same part on Amazon. We'll see if it works and I'll post here the part number with the old alpha suffix.
