Turn Signal Failure Only in Left Rear - Tried Everything! (I think)
Hi Everyone,
In need of some advice. I have a malfunctioning left rear turn signal. When I brake, this bulb illuminates no problem, leading me to believe the bulb is fine. All other turn signals and respective lights are functional (minus one tag light). I have checked the respective relay and the fuses. Swapped in known good ones to no avail. Oddly enough, when I signal to the right ( where both front and back signals are functioning), I see no green arrow on my dash but I do hear the clicking. When I signal to the left (where only the front flasher is functioning), I see the familiar green arrow and hear the relay clicking. I'm beginning to suspect the actual turn signal switch/stalk itself. Spending hours looking at wiring diagrams trying to determine if there is a separate electrical current being sent out to the front and back flashers or if they share a circuit. Any advice to point me in the right directions is greatly appreciated. Need this truck to be ready for inspection Thursday morning (UPS seasonal work). Thanks guys!
It's been forever since I switched to aftermarket LED tails, but I think the bulb may have two filaments. So, the flasher filament could be out and the bulb still work for brake lights. Try swapping the bulbs side to side. If the problem follows, it's the bulb.
Hi Everyone,
