the early V8 ones all had the heavier trans in them esp the 4wd A518 they were called then. now called 46RH. I have had several Dakotas and the only ones I have had that didn't come with the 46 RH/RE were the 6 cylinder ones. my 92, 93 and 96 were all V9s and had that trans in them, while my 90, 94 and 99 are/were V6s and came with the 42/44 series (the 42 and 44 look identical from the outside, differences were internal, related to number of clutch discs in each clutch pack) and I put a 46RH into my 94 V6 truck, bolted right in. only difference noted in the swap were the bellhousing inspection cover and the dipstick/tube.
the torque converters btween them were different but bolted up to the engine the same as each other. same mounts, same driveshaft, same electrical plugins.
