Ticking When Accelerating
Old Dec 8, 2019 | 04:18 AM
acesofwar's Avatar
acesofwar
Default Ticking When Accelerating
My 1998 Dodge Dakota with the 2.5 and 5 speed M has a ticking noise when accelerating. It doesn’t do it on start up or downshifting- only when accelerating or putting a load on the engine. The more I press the gas down the louder ticking.
Any help is much appreciated!
Old Dec 8, 2019 | 08:39 AM
Sounds more like pinging. Or a exhaust manifold leak. What grade gas you using? Last tune up?
Old Dec 8, 2019 | 11:51 AM
acesofwar's Avatar
acesofwar
I use 87 grade but I’ve tried 89 with no change to the noise. Last tune up where the spark plugs were changed was about a year ago. I got a brand new engine about 20k ago and the last one busted it’s #4 piston head.
What would be the best and easiest way to check for a exhaust manifold leak?
Old Dec 8, 2019 | 12:23 PM
Dodgevity's Avatar
Dodgevity
At the risk of sounding simplistic, have you checked the oil?
Old Dec 8, 2019 | 12:51 PM
magnethead's Avatar
magnethead
I'm guessing exhaust leak
Old Dec 8, 2019 | 03:35 PM
acesofwar's Avatar
acesofwar
I have. That’s the first thing I thought too
Old Dec 8, 2019 | 03:44 PM
acesofwar's Avatar
acesofwar
What would be the best way to test for that? I also feel like I should mention the exhaust is about half the original length.
Old Dec 9, 2019 | 08:20 AM
Check the exhaust manifolds where they attach to the heads. Check for broken studs. Check for indications of blown gaskets (black, sooty deposits around the edges)
Old Dec 9, 2019 | 08:36 AM
Dodgevity's Avatar
Dodgevity
What is your oil pressure gauge saying? If you don't find anything exhaust related, I'd be tempted to test oil pressure with a good gauge.
Old Dec 9, 2019 | 08:01 PM
acesofwar's Avatar
acesofwar
Oil pressure reads a little high but nothing out of the ordinary. Probably about 70-80 lbs?
