Parasitic draw
Old Mar 2, 2020 | 06:53 PM
NAS1966's Avatar
NAS1966
Default Parasitic draw
Bought Dodge Dakota V6 3.7L , Automatic truck used - battery drained after standing 1 1/2 days. Checked everything, pulled all fuses and relays in fuse panel. Nothing . Discovered ground cable leading to starter. Starter was "grounded out".
Installed new starter, still measuring 3.6amp DC. Disconnected heavy red wire connecting fuse box.- ZERO amp DC. What else can cause such high draw?
Old Mar 2, 2020 | 07:02 PM
00DakDan's Avatar
00DakDan
Section Moderator
3.6 amps is a good draw.
Start pulling fuses to see if you can narrow it down.
Old Mar 2, 2020 | 10:48 PM
magnethead's Avatar
magnethead
Unplug the CTM in the driver kick panel.
Unplug the audio amplifier (if present) in the passenger kick panel.
