Front Diff Grenaded
Old Mar 15, 2020 | 07:44 PM
Teckus's Avatar
Teckus
Default Front Diff Grenaded
So I have an AWD 2002 Dakota with the 5.9L V8, was driving and i stoped for a stop sign, then I started driving and I heard a thumping and it got faster as I drove faster, so i slowed down. I stopped, checked under and nothing seemed wrong, was having it towed and the guy tried to drive it onto the truck and the front diff grinds for around 3 seconds before we stop and he just sticks it into neutral. I was wondering if I can just take out the front drive shaft and forget about AWD, the truck is rusted out because of previous owner and im looking at buying a new one, just need a vehicle to get around in. Would all I have to do is take out the front drive shaft and I could drive it like that or more than just that?
Old Mar 15, 2020 | 08:56 PM
If you have a part-time 4wd position, then yes, you could do that. In awd the truck wouldn't move though. It would just spin the front drive flange. Need the t-case locked.
Old Mar 15, 2020 | 10:19 PM
Teckus's Avatar
Teckus
My truck has AWD, 4lo,4hi but it never worked since ive had the truck, and the shop told me that my t case was welded, but I don't know what they really meant by that if they didn't know it was AWD or not.
Old Mar 15, 2020 | 10:37 PM
magnethead's Avatar
magnethead
Could probably pull the front shaft and put the case in 4-hi
That said, depending on how wasted the front diff is, it may not matter. The front axle is live, theres is not a disconnect.
You could however pull the front driveshaft as well as the two CV shafts. They spline into the front hub IIRC.
Old Mar 15, 2020 | 11:16 PM
Teckus's Avatar
Teckus
What if my 4wd never worked? It would never engage into anything but AWD couls I still pull the front shaft out? And do I need to take out the cv axles?
Old Mar 16, 2020 | 08:15 AM
I think you need to start looking for a front axle, and t-case. Either that, or a whole new truck. (new to you at least.) You can't pull the front axles completely. You would need to leave the outer stubs in the hub/bearing unit, as that is what hold them together. Without those stubs/nuts, the bearings can easily separate, and you loose a tire. No fun at all.
Old Mar 16, 2020 | 08:32 AM
Teckus's Avatar
Teckus
well since I think it's my front diff, but I'll find out for sure today, I think I'd need new diff, t case, and maybe axles, that's give or take 500$ in parts and I'm not planning to drop a diff In my driveway, so I think I'll go with the new truck idea lol
