Need help or advise please
Old Apr 19, 2020 | 10:44 PM
Jeff1793's Avatar
Jeff1793
Default Need help or advise please
Hi there I new to this forum posting. But here’s my story. I bought a 2003 dodge Dakota 4.7 v8 for 100$ it had a blown engine. So I got a 2000 Dakota 4.7 v8 with a running engine. So I swapped the 2000 into the 03 but after everything was hooked up and turning over but won’t start. Found out the 03 engine had a 32 tooth crank ring and the 00 is a 16 tooth.
Has anyone come across this problem?
Is there anyway to fix this without changing the crank ring?
Old Apr 19, 2020 | 11:09 PM
magnethead's Avatar
magnethead
No way around it. Have to take it apart and switch tone rings.
Old Apr 20, 2020 | 12:22 AM
98DAKAZ's Avatar
98DAKAZ
That means rebuilding the engine as the tone ring in inside the engine case.
Old Apr 20, 2020 | 01:13 AM
Jeff1793's Avatar
Jeff1793
What about reprogramming the ecm? Has anyone tried that?
Old Apr 20, 2020 | 10:16 PM
magnethead's Avatar
magnethead
The harness is electrically different. 16 tooth PCM has 3 connectors on the JTEC programming language, 32 tooth has 4 connectors on the Next Generation Controller programming language. NGC controller has a much faster CPU that can process the faster pulse speed of having twice the teeth.
