trans go ?
hi all i am a newbie but have done some research.i had trans go kit recently installed and all went well.still early but firm.4 weeks later it seems to have gone back to stock which is impossible because of mods to v.b. different springs settings etc. i will say with some history it has 130000 miles on it.shifted fine before trans go.changed trans fluid twice but not the time of trans go kit(was just changed when i replaced governor solenoid and transducer a month ago.reused 1 month old fluid .i might add i didnot drain convertor either.oh also only changed filter once the first time.original fluid(130000) looked good other than the normal buildup around magnet.what would cause soft(normal) shifting now??? if i have to drop the pan and get this blood bath i will put a drain plug in this time.any suggestions would be appreciated.
