Lifting the 03 and 04
Old Jun 4, 2020 | 11:55 PM
akeED's Avatar
akeED
Default Lifting the 03 and 04
Does anyone know anything about this, like if it's true?
You can use an 02 kit with 02 brake parts to lift your 03/04.
The parts costed about $200 more and here is the list of parts needed the part # for the rotors 488-6645, calipers 442-3116m and 442-3117m these numbers are NAPA #//// banjo bolt 6504019, caliper support spring 52010170, right splash shield 52008990, left splash shield 52008991, these part # are dodge # you need 2 of each part for the banjo bolt and caliper support spring
