How do you get o rings out of the radiator? Also where can you get the orings?
Old May 30, 2020 | 01:12 AM
Barcelona28's Avatar
Barcelona28
New Member
Default How do you get o rings out of the radiator? Also where can you get the orings?
2005 dodge Dakota. New radiator from rock auto. Leaking trans fluid from the radiator connections. How do you replace the orings? I have heard use a pick and pulled them out. Where do you get the orings from? Dealer says you have to get a whole new one or go to Ace hardware store to match them up. I don't know.
Old May 30, 2020 | 10:17 AM
magnethead's Avatar
magnethead
pick and ace are best options.
Old May 30, 2020 | 04:17 PM
Vimes's Avatar
Vimes
I just had that exact same problem on my Colorado work truck. Installed a new radiator from NAPA, started leaking at the trans cooler line. Turned out that the black sheet metal bolt that holds the fitting to the radiator was the problem, not the cooling line O-ring. But, it looked exactly like the O-ring was leaking. I tightened up the bolt, and it sealed right up. The one that was leaking was barely finger tight. If this is the case with yours, it doesn't take much to tighten it down so don't crank on it too hard. Just a firm twist with a wrench, maybe 30-40 ft lbs at most. These parts are delicate where tightening bolts is concerned.
Old May 31, 2020 | 07:26 PM
Barcelona28
New Member
Thank you both. Going to check both things just in case. Been dripping a lot.
Old Jun 1, 2020 | 11:59 AM
Zingo's Avatar
Zingo
Also be very careful not to cross thread the fitting into the radiator when you put it back together.
In my experience it can be sort of difficult to get it lined up just right because of the strange angle you have to work with. It should thread in part way with your fingers if you got it right.
I just replaced a radiator in an '03 Durango 4.7l and it look me like 10 minutes of frustration before getting one of the fittings started. I felt kind of dumb for taking so long but that's just the way it goes sometimes and it has to be perfect.
Old Jun 1, 2020 | 12:40 PM
Barcelona28
New Member
Ok. The person who is helping to do this says I have to get a new radiator. The rock auto ones don't line up always going leak. But I disagree with him i want to try the bolts and orings just to see if does stop leaking hopefully fixed. Before I spend money again.
Old Jun 1, 2020 | 04:14 PM
Dodgevity's Avatar
Dodgevity
I'd be taking that up with Rock Auto to get a refund or return credit.
A little tidbit that I learned while working on my truck. When draining the radiator.... you can access the draincock by sticking your hand through the bumper cutout shown here. It drains down into the inside of the bumper, so stick a turkey pan underneath.
Old Jun 1, 2020 | 07:12 PM
magnethead's Avatar
magnethead
I only use CSF radiators or higher quality than that.
Old Jun 2, 2020 | 08:17 AM
Dodgevity's Avatar
Dodgevity
Likewise. I've got the CSF 3516. Core thickness is 1.63" vs 1.25" of the typical aftermarket. It replaced my OEM heavy duty cooling radiator that came with the tow pkg. I've never even come close to overheating even when towing cars in the summer.
Old Jun 6, 2020 | 09:45 PM
Barcelona28
New Member
Thank you all of you. It's fix now! Thank you again
