Getting trouble codes
Old Dec 20, 2005 | 11:18 PM
Ringering06's Avatar
Ringering06
Default Getting trouble codes
So my check engine light is on. I went up to AutoZone and had them read the code for me, but I know you're supposed to be able to get the code off the odometer readout. I've tried several variations of the on-off-on-off-on with the key, and done the system check by holding in the trip button while turning the key on, but I can't get the trouble codes to come up on the odometer. What am I doing wrong? I got the key sequence to work on our 02 Caravan, but can't get it to work on my 98 Dakota.
Old Dec 21, 2005 | 10:04 PM
kota98's Avatar
kota98
Default RE: Getting trouble codes
98 dont have the On Board coders on the truck got to get a scanner
Old Dec 27, 2005 | 03:01 PM
brian2171's Avatar
brian2171
So......what was the code telling you at Auto zone? Did you cure the problem? It sounds like you should get a Superchips tuner, then you can read codes and get more power as well.
Old Dec 27, 2005 | 03:41 PM
Ringering06
The code was a misfire on cylinder 6. Not sure what the problem was, but it hasn't happened again, and that was quite a while ago. Anyway, how much are we talking for one of these tuner chips? I've heard there's a lot of rip-offs out there, as well as chips that really are worth it. How much should I be looking to pay?
