5.9 dakota installed a nv3500 now it backfires when giving it gas help
So i swapped my 46re out for a nv3500 and now it backfires when i give it gas idles just fine relaced pcm with it
so i need a new crank sensor i know that there diff the one for a manuel is plastic and the one for a auto is metal three also 2 diff heights iv got the correct one in that matches the transmission thanks for your help man i need my baby back on the road
Yep, if you changed the crank sensor before putting the bellhousing on, it won't run right. Have to put the bell on first, then put a new crank sensor in. Otherwise it will remove material from the end of the sensor usually.
Also, a factory sensor is suggestable. I went through random misfire codes with box store ones. They magically went away with a genuine mopar (NTK).
