Transmission fluid leak
Old Sep 26, 2020 | 07:18 PM
tgotr's Avatar
tgotr
Problem fixed. I still have a transmission fluid leak out of one of the cooler lines. I wonder if it would be wise to cut the bad section out and replace it with soft line being that it's near the exhaust pipe. It's just a drip, but stop leak hasn't done anything and leaking fluids is wasted money.
Old Sep 27, 2020 | 03:10 AM
Dodgevity's Avatar
Dodgevity
Have you priced the line? Might be less hassle to replace, rather than cobble something together.
Old Sep 27, 2020 | 12:43 PM
tgotr's Avatar
tgotr
$148 for the upper line. I traced the line, and it connects to the radiator, so I have to tear out the reservoir.
Old Sep 27, 2020 | 01:45 PM
Dodgevity's Avatar
Dodgevity
Not sure what you mean by "I have to tear out the reservoir." The lines connect at the side of the radiator/cooler and unscrew right there. I see all kinds of prices for lines. Post your truck details or better yet, add them to your signature.
Old Sep 27, 2020 | 02:03 PM
tgotr's Avatar
tgotr
'02 Dodge Dakota SLT Quad Cab
4.7L V8 engine
Automatic Transmission
4WD.
I'd like to fix this cheaply.
Old Sep 27, 2020 | 05:52 PM
magnethead's Avatar
magnethead
You can splice it with a rubber line, but you'll want to flare/knurl/roll the cut end slightly, and double clamp both ends of the rubber hose.
Old Sep 27, 2020 | 05:53 PM
tgotr's Avatar
tgotr
OK, so the close proximity to the exhaust line won't harm the rubber line?
Old Sep 27, 2020 | 06:27 PM
Dodgevity's Avatar
Dodgevity
4.7L V8 engine
4WD.
Got a part number?
Old Sep 27, 2020 | 10:04 PM
magnethead's Avatar
magnethead
Oh! yea, if it's near the exhaust, you're going to have problems. Using a stainless braided 6AN hose will buy you some time, but it will likely eventually melt from the heat as well.
