2001 Dakota brake controller
Old Sep 28, 2020 | 07:54 PM
tlcvac's Avatar
tlcvac
Default 2001 Dakota brake controller
Parts guy says per the VIN that the truck has TRAILER TOW GROUP installed. Which means truck has all the wiring needed EXCEPT the controller. Sold me a brake controller and said to plug it in to a connector behind the dash. Said the connector should be white.
I am unable to locate the connector.
Anyone know exactly where it is located?
Thanks for any assistance, Tom/Idaho
Old Sep 28, 2020 | 10:56 PM
magnethead's Avatar
magnethead
It should be tucked up behind the driver side fuse block, up above the parking brake. My truck didn't have tow group, but that's where the connector was on both our 2005 and 2011 rams.
Old Sep 29, 2020 | 08:34 AM
Dodgevity's Avatar
Dodgevity
From the interwebs:
"The plug for a brake controller will only be present/functional if your 2003 Dodge Dakota came with a factory installed 7-Way trailer connector. The factory plug is located underneath the dash, to the left of the steering column, taped to another harness near the emergency brake pedal.
Sometimes the connector will be tucked up with other wires, taped up so it isn't easily visible, or it could be behind the driver's side kick panel."
Old Sep 30, 2020 | 07:18 PM
tlcvac's Avatar
tlcvac
Default 2001 brake controller
From the interwebs:
Thank both of you. I found the connector. I don't think I would have looked there if not for your information.
Thanks again, Tom/Idaho
